Eastport Pram
£1180
£67.90
£30
£1
£860
£980
£1090
£1140
£345
Prices include VAT.
The Eastport Pram, with more than 800 built, is one of the most popular small dinghies.
The design and the kit you produce is really first-class.
K.A.M.
The Eastport Pram is pretty, light, tough, roomy, and easy to build. It is just 7′ 9″ long and 48″ wide, but will hold about 375 pounds. She's built from 6 mm okoume using the LapStitch method so that it resembles clinker. The finished boat looks like it was built by a seasoned craftsman, but it will take a novice only about 50 hours to assemble the Pram.
This boat is for people who want a light boat to take to different waters and to mess about in when on holiday. The Eastport Pram is so light it is very easily put on a roof rack. It is small enough to be carried whilst towing a caravan. Many people use inflatable boats to ferry goods and crew between the shore and their main boats. The problem with inflatable boats is that they are hard to row so inevitably noisy outboard motors are needed. The Eastport Pram is designed to overcome the problems and be light and easy to row.
Small tenders should be able to withstand heavy handling alongside the mothership or in the dinghy park. Planking is 6 mm okoume throughout, with three 9 mm frames and seats. There's a big, deep skeg for tracking under tow. In addition to fibreglass reinforcement on the bottom panel, there are two rubbing strips on the bottom to take the abrasion of dragging on a beach. For added safety, permanent flotation tanks are built in beneath the seats.
The Eastport Pram has a deep rocker for low wetted surface and to keep the transoms from dragging. The result is a boat that is as easy and satisfying to row as you can expect on such a short waterline. Used as a tender to a larger boat, or kept at a dock, it's possible to undertake a long afternoon row around the local waters without breaking a sweat.
The Eastport Pram is built using CLC's patented LapStitch™ joints which means that the result is a remarkably stiff and strong hull that has the appearance of traditional lapstrake or clinker planking.
This is Mark II of the Eastport Pram: the panels on this kit are pre-drilled and the bulkhead positions are pre-marked so that it is possible build the boat without having to measure for locations.
This pram would also make a great first boat-building project, a wonderful fishing boat for a small lake, or a child's first boat.
There is also a Nesting Eastport Pram, which is split into two sections so that the forward section can nest completely in the aft section for compact storage.
We recommend 6ft 6in oars for this boat.
Few have visited without taking her out for a spin and learnt – or relearnt – the pleasure of messing around in small boats. And one of the nicest features is the smile she puts on people's faces when they're not even sailing her. We often feel like minor celebrities when sailing her with people taking photos or calling out ‘nice boat!’.
Mungo and Rosie
What is in a boat kit.
Plans and manual
The manual is the one that accompanies the kits. It describes all of the techniques that will be used during the building and also a step by step guide to construction. Scale drawings are used throughout as well as photographs of critical jobs.
Using the plans of the panels with the cutting instructions it is possible to build the boat from scratch.
The plans for the standard Eastport Pram are currently only for the Mark I. The plans for the Nesting version are for the Mark II and contain full-size drawings for every part.
Wood
This option contains the pre-cut wooden components with pre-cut joints, plus the construction manual. It does not contain the plans (these are not required because the wood is pre-cut), any of the epoxy to glue and coat the boat, the fabric or tape nor any of the hardware.
Sailing option
This option can be retrospectively fitted and it turns the Pram hull into an able sailing boat. The rig is powerful for its size and easy to set up and handle. Please note that the base kit (or a completed hull) is needed in addition to the sailing option.
With the optional sailing rig the pram makes a splendid sail trainer. Tiny responsive boats like this offer immediate feedback and give sailors tremendous confidence in their ability to predict how any boat will behave. It is often said that you will learn more about sailing in a few days in a dinghy than in years of ‘cruising’ in big boats. Many big boat sailors still get nervous sailing up to a dock or manoeuvring through a crowded harbour without an engine. These are the very skills that are improved in tiny boats. Of course, improving sailing skills is not the only reason to sail a dinghy; charging around in the Eastport Pram is simply fun. The Pram has been designed with a strengthened hull and longer skeg to make it ideal for towing as a tender.
The option includes:
The sailing option does not include the warp although we can supply it.
Broken inwales option
Broken inwales add elegance to any boat by mimicking the ends of the ribs in traditional frame-built boats. This option includes everything you need to install broken inwales in the Eastport Pram:
